nm_FEATURE_TYPES - A Published Paramater is troubling datadownload process
  • Jul 31, 2019 11:39 AM UTC
  • 7 replies
  • 78 views
Hello Safe, i have one published parameter name "FEATURE_TYPES" and it basically defines data from a ESRI geodatabse. The download process works good with this parameter. Problem is happing when I change the name into "nm_FEATURE_TYPES". The data download process stopped and giving the error:
statusMessageParameter 'nm_FEATURE_TYPES' must be given a value. statusFME_FAILURE
This there any solution for me thus i can use the name nm_ for my Published parameter?
With kind regards
Muqit Zoarder
  • Jul 31, 2019 11:54 AM UTC
Sounds like the workspace is started without any value for the mandatory published parameter.
How are you starting the workspace?
The workspace is connected to ESRI geodatabse, and linked with Published parameter,
If I run then the nm_feature_types is not pulling any data
  • Jul 31, 2019 12:19 PM UTC
Thanks for sharing the setup. How are you executing/starting the workspace? From a batch file, command line, FME Server, other?
fme server run the workspace for datadownloading
  • Jul 31, 2019 3:18 PM UTC
Have a look at the job log, in particular do a search for "nm_FEATURE_TYPES" and see if the parameter was correctly transferred (has a value) to the FME engine.
Hi, no job log is creating, only shooting this error:
  • Aug 2, 2019 6:08 AM UTC
Are you absolutely certain that you have specified a value for nm_FEATURE_TYPES before submitting the job?
If so, you may want to contact your local FME reseller for further support.
