My Shutdown Python Script is calling arcpy to run the Arc Extend and Trim tools on my dataset, is there a way to have inspector display the results?
  • Aug 17, 2017 10:18 PM UTC
  • 79 views
  • Aug 18, 2017 12:37 AM UTC
Hi @apadilla, I think that a quick way is to create and run another workspace which contains:
  1. WorkspaceRunner (Wait for Job to Copmlete: Yes): Run your workspace.
  2. FeatureReader: Read the resulting dataset created by your workspace.
  3. Inspector: Review the dataset with FME Data Inspector.
  • Aug 18, 2017 7:06 AM UTC
An alternative to Takashi's suggestion could be
Data -> FeatureWriter -> PythonCaller with arcpy -> FeatureReader -> Inspector
In other words, moving the arcpy code from the shutdown script into the PythonCaller. This way you won't need more than one workspace.
