loose match
  • May 18, 2015 8:23 PM UTC
  • 8 replies
  • 69 views
Good afternoon,
I have this issue come up now and again and I'd like to be able to solve it. But I frequently get excel spreadsheets that neet to be mached to a Point Layer in SDE. Normally I take the geometry of the SDE layer and keep the attributes of the spreadsheet. I normally use the FeatureMerger transformer. My problem is sometimes the number I use to match on is sometimes odd in the spreadsheet such as having trailing zeros or just any number of extra characters (normally 8000+ rows). So question being is there a way to do a "Loose match" on the fields to come up with a match? Thanks!
Best answer by takashi
The StringFormatter might help you.
Format String: -014s
The format string means:
- the minimum number of characters should be 14
- add trailing zeros if the original number of characters is less than 14.
See the help on the StringFormatter to learn more about the fomat string.
  • May 19, 2015 8:47 AM UTC
If you need to ignore all trailing zeros and non-digit characters in the number coming from the spreadsheet, one possible way is to remove them using a StringReplacer with this setting beforehand.
Test to Match: (.*[1-9])([^1-9]*)$
Replacement Text: \\1
Use Regular Expressions: yes
But it doesn't work for a case where the number coming from the SDE table ends with "0", e.g. "120". If there could be such a case, you will have to think of other approaches.
Takashi
gio
Forum|alt.badge.img+15
  • May 19, 2015 1:00 PM UTC
..i bet he meant leading zero's
  • May 19, 2015 2:12 PM UTC
Thanks for the replies. In some instances it would be leading. Since this does not seem to work on SDE what would be the Regex for adding 4 zeros to a 10 digit number so as to modify the excel side?
  • May 19, 2015 2:25 PM UTC
Could you please show us some examples of the original string and the preferable result after modifying?
  • May 19, 2015 2:40 PM UTC
Yes, in this case nearly all the records are 9 to 10 characters long. 3507725552 -> 35077255520000 or 307170548 -> 30717054800000.
  • May 19, 2015 2:57 PM UTC
  • May 19, 2015 3:07 PM UTC
Thankyou, I can't believe I didn't see this when looking through the transformers. But makes perfect sense.
  • May 19, 2015 3:22 PM UTC
A little bit advanced technique.
You can also set this expression directly to the "Join On" parameter of the FeatureMerger.
@Format(%-014s,@Value(the_number_attribute_name))
@Format is one of the FME String Functions, the behavior is almost equivalent to the StringFormatter transformer.
String Functions (http://docs.safe.com/fme/html/FME_Transformers/FME_Transformers.htm#transformer_parameters/StringFunctions.htm)
FYI
