Loop through records and build trace connectivity
  • Mar 16, 2021 9:40 AM UTC
  • 13 replies
  • 87 views
sunsilk11
Hi I have a table containing 2 columns StartPt and EndPt [see attached].
I would like to find all the connected nodes for each StartPt in the table.
For example, the connected nodes for Startpts 107224 and 100561 are:
StartPt EndPt
107224 100561
107224 101420
107224 107197
107224 107196
100561 101420
100561 107197
100561 107196
100561 103058
Any suggestion how this can be achieved in FME. Alternatively, I could look at doing this via a stored procedure.
  • Mar 16, 2021 12:58 PM UTC
Hi! If you put an aggregtor and group by StartPt - and put EndPt as for example a string to concatenate (or build a list), that should give you one feature per StartPt, with your set of EndPts either as a list or as a concatenated string. Where will the endpoints go afterwards? That might have an impact on the list-vs-concatednated-string approach.
sunsilk11
  • Mar 16, 2021 2:07 PM UTC
Thanks for the response. However just the aggregator alone won't work. In the example given , 107224 does not connect to 101420 directly. It only does so via 100561
Seems a bit more involved than it looks.
@Takashi Iijima​ , @daveatsafe​  - any ideas ?
daveatsafe
Forum|alt.badge.img+24
  • Mar 16, 2021 4:29 PM UTC
Hi @sunsilk11​ ,
If you had geometry on the data, the NetworkTopologyCalculator would give you the answer, but in this case I think you may need to use the PythonCaller to code a solution, or perhaps the InlineQuerier if you prefer SQL.
connecter
Forum|alt.badge.img+10
  • Mar 16, 2021 4:42 PM UTC
Hi @sunsilk11​ ,
Maybe 2x VertexCreator behind each other can build a line and after it the NetworkTopolgyCalculator can identify same Networks?!
hkingsbury
Forum|alt.badge.img+73
  • Mar 16, 2021 7:18 PM UTC
Create two points one using the StartPt as your X and Y value, and the Second using EndPt as your X and Y value. You can then use a spatialrelater to find which points overlap. You'll then have a list of FIDs (or create a new UUID before making the points) of which are connected
sunsilk11
  • Mar 17, 2021 9:35 AM UTC
@connecter @daveatsafe​
Thank you. I do have the line geometry. However the network is built with the startpt/endpt attributes. NetworkTopologyCalculator does not have the options to use the attributes.
I'll probably go with PythonCaller
Forum|alt.badge.img+54
  • Mar 18, 2021 8:45 AM UTC
NetworkX is good for this sort of thing if you're going to use python
sunsilk11
  • Mar 18, 2021 12:00 PM UTC
Thanks. I am thinking this may be best done outside FME as would probably require nested loops.
  • Mar 18, 2021 12:40 PM UTC
It should be quite straightforward if you are able to install the networkx python module. I can post an example later​
  • Mar 18, 2021 2:03 PM UTC
Although, I'm not clear why in your example 107224 is not linked to 103058 and beyond as it would appear it goes
Capture
sunsilk11
  • Mar 18, 2021 6:22 PM UTC
You are right. 107224 is connected to these 3 nodes too.
sunsilk11
  • Mar 19, 2021 12:16 PM UTC
@ebygomm​  Yes you are correct. It was a mistake above. 107224 does link to these 3 nodes too
  • Mar 19, 2021 3:26 PM UTC
And 102412 & 107206 ?
