Loop through attributes by specific id that matches column name
  • Oct 21, 2019 10:01 AM UTC
  • 5 replies
  • 111 views
freddie_kwak
Hello everybody,
I hope somebody can help me with the following challenge:
I have 2 datasets/dataflows in a workbench:
-1. MeldingData: One set contains registered data like roadnumber, type of animal, status, etc
-2. FormData: The other set contains the pulldown menu options from the iASSET application database where the value is shown in the first dataset.
The set MeldingData has colomn names like data.100003, data.100004, data.100024, etc. The number of the colomn from MeldingData matches the colomn id from FormData.
I want to replace the code in MeldingData with the matching value/label from FormData, so it makes the dataset more readable.
An example: the first row of MeldingData has value 05 in colomn data.100004. This means that this notification/call is made on roadnumber N373. Al the other colomns need to be processed simmilar.
I attatched the workbench and an excelfile with the MeldingData and FormData.
I hope you understand my explanation. If you need more information, please let me know.
Kind regards,
Freddie.
arnovananrooij
Forum|alt.badge.img+5
Hi Freddie,
You could use an InlineQuerier to solve this. I have made a begin with the query to use. This query looks up labels for data.100003 and data.100004. Just add all the other columns the same way. The query to use is:
select "MeldingData"."id"
, "MeldingData"."latitude"
, "MeldingData"."longitude"
, "MeldingData"."pin_icon"
, "MeldingData"."locally_created"
, "MeldingData"."data.100003"
, "fd100003"."label" as "label.100003"
, "MeldingData"."data.100004"
, "fd100004"."label" as "label.100004"
from "MeldingData"
, "FormData" fd100003
, "FormData" fd100004
where "fd100003"."id" = 100003
and "MeldingData"."data.100003" = "fd100003"."value"
and "fd100004"."id" = 100004
and "MeldingData"."data.100004" = "fd100004"."value"
The workspace itself will be pretty easy:
Greetings
Arno
gio
Forum|alt.badge.img+15
  • Oct 21, 2019 10:33 PM UTC
@freddie_kwak
Featuremerger solution. more generic(ish) and less typing ;)
Dynamci key Kwak.fmw
gio
  • Oct 22, 2019 11:51 AM UTC
@freddie_kwak
Updated, added the not merged objects (in case you did not figure it out yourself, which is presumed)
31082-dynamci-key-kwak.fmw
Ouptutexample added.
Question;
Are integer values in the data. columns which are seperated by comma' s multiple values ?
freddie_kwak
@freddie_kwak
Question;
Hello Gio, sorry for my late reaction! The data. columns do not have multiple values. Always a single value. Thank you for your help! It works realy well! learned a new FME-skill! Thank you for that!
freddie_kwak
Hi Freddie,
from "MeldingData"
Greetings
Arno
Hello Arno, thank you for the solution! Also works very well! Sometimes difficult to understand for me, but good to know i can solve these kind of problems with the InlineQuerier! Thank you for your help!
