Lookup a specific re-ocurring attribute and return Yes/no depending if all occurences of the attribute possess a populated date column
  • Feb 21, 2019 3:06 PM UTC
  • 7 replies
  • 91 views
I have tried and failed and tried and failed. Any help is extremely appreciated in advance!
I have column1 containing reference numbers (with duplicates) and I have column2 containing dates (and blanks). I want to create column3 and return yes/no values for all the reference numbers, depending if all ooccurrences of each reference number contains a populated date field. e.g:
input:
RefDate101/01/2019101/01/2019
201/01/2019
201/01/2019
2
301/01/2019
3
401/01/2019
401/01/2019
Output:
RefDateNewField101/01/2019
Yes101/01/2019
Yes201/01/2019
No201/01/2019
No2
No301/01/2019
No3
No401/01/2019
Yes401/01/2019
Yes
Thanks,
Sideshow
Additionally, I would then like to create another new field, that details the latest date of each reference number that returned "No" previously.
jdh
Forum|alt.badge.img+41
  • Feb 21, 2019 3:29 PM UTC
Aggregate (with List) group by Ref, ListSearcher on _list{}.Date for the nulldate value (null, empty string), if found AttributeCreator Newfield = No, ListSorter (Date, descending order), ListIndexer (0, prefix latest_), if not found AttributeCreator Newfiled = Yes.
Both streams should then go to a deaggregator.
Forum|alt.badge.img+54
  • Feb 21, 2019 3:43 PM UTC
How about some sql in the InlineQuerier?
Select *, CASE WHEN dd.Ref IS NULL THEN "Yes" ELSE "No" END AS NEWFIELD from
(SELECT AA.Ref, AA.Date, Max.Latest_Date from Sheet1 aa,
(SELECT Ref, MAX(DATE) AS Latest_Date FROM "Sheet1" GROUP BY Ref) max
WHERE AA.Ref = max.Ref) cc
LEFT OUTER JOIN (SELECT Ref FROM "Sheet1" WHERE DATE IS NULL) dd
ON cc.Ref = dd.Ref
In reality I'd probably use this sort of workflow
  • Feb 21, 2019 4:15 PM UTC
ON cc.Ref = dd.Ref
Hi Egomm, many thanks for the response.
Forgive me if the answer is obvious, but what exactly is going on with the tester and featuremerger in your screenshot? I have managed to use the statisticscalculator successfully to calculate the max date, but cannot seem to create a yes/no value based on whether all occurrences of the reference number possess a date.
Many thanks,
Sideshow
  • Feb 21, 2019 4:19 PM UTC
Many thanks,
Sideshow
The tester filters out all the references with null values which then exit the failed port. These are then used as suppliers in the featureMerger. This way, only refs that have null values exit the merged port, everything else exits the unmerged requestor port
  • Feb 21, 2019 4:33 PM UTC
What are you merging on in that feature merger?
  • Feb 21, 2019 4:44 PM UTC
Using Ref as both Requestor and Supplier
