Lookup
  • Mar 31, 2019 8:29 PM UTC
  • 35 views
perry
Hello,
I've studies lookup solutions but Iit still does not work.
I have 2 ora-tables.
- a lookup table KALENDER with DATE_START and DATE_END and a corresponding number ie
DATE_IN DATE_OUT PERIOD
20181101 20181124 10
20181125 20181212 11
20181213 20181215 12
20181216 20190114 13
20190115 20190125 1
20190126 20190228 2
20190301 20190310 4
20190311 20190322 5
- a table with a dossiernumber and a DATE_INVOICE.
DOSSNR DD_INVOICE
D099 20181120
D099 20190305
D125 20190127
D125 20190315
D127 20190306
There are more invoices per DOSSNR / YEAR.
The output should be like:
DOSSNR YEAR_2017 PER_2017 YEAR_2018 PER_2018 YEAR_2019 PER_2019
D125 2019 2,5
D127 2019 4
D099 2018 11 2019 4
Can you help me?
  • Mar 31, 2019 10:07 PM UTC
The InlineQuerier and some transformers might help you. For example, this workflow
generates this table.
In your output table, it's unclear how the field values should be corresponding to the header (field names), so the workflow above is not completed yet.
Could you post your desired resulting table again with the "Insert Table" function?
perry
  • Apr 1, 2019 9:18 AM UTC
@takashi
Thank you very much, your solution is sufficient and I have the desired output.
