ListBasedFeatureMerger with list as Supplier key ?
  • Jul 16, 2019 1:55 PM UTC
  • 82 views
Hello,
I'm trying to find an elegant solution for a feature merge based on the same list, twice.
So, data is a shapefile with polygons as features. Each polygon have a _class{}.ID list. The goal is to compare each _class{n}.ID to other polygons (not itself) _class{n}.ID (nmax is different for each polygon), to finally agglomerate their geometry.
Issue is that ListBasedFeatureMerger takes attributes as supplier key and not lists.
Example:
NAME
_class{0}.ID
_class{1}.ID
_class{2}.ID
Oscar
27
92
1
Tango
1
Charlie
<Missing>
<Missing>
<Missing>
Golf
22
12
Whiskey
92
Hotel
137
4
6
So here, Oscar, Tango and Whiskey would be agglomerated.
How could that be done ?
Thanks
Best answer by ebygomm
Take a look at the custom transformer - ListCombiner
This will assign a common group value to all attributes that share values in a list
Forum|alt.badge.img+54
  • Jul 16, 2019 2:07 PM UTC
Thanks, it worked exactly as intended !
