JobSubmitter successful, despíte wrong parameter
  • Jun 27, 2018 2:39 PM UTC
  • 22 views
Hi there,
I've developed a FME-workspace with user-parameters. One of the Parameters is a defined "Choice-Parameter". On Desktop it works fine, the same on FME-Server.
I'm also using the Url for the workspace to submit the request in a Browser. Now it's possible to alter the Choice-Parameter with some fantastic values (Example: Choice-Parameter: "Numbers: 1|2| 3"; in URL written Value: "Numbers: 4"). The result I receive is empty, as expected. But the Workflow "completed successfully" too.
My question: Is there a possibility to force the FME-Server in a "Failed", when the defined Parameter got a wrong value?
Thanks for your help,
Greetings,
André
  • Jun 27, 2018 2:41 PM UTC
You can use a Tester/TestFilter to check for valid parameter values and trigger the Terminator if an invalid value has been defined.
