Iterating a workspace over feature types
  • Mar 1, 2013 6:52 PM UTC
  • 70 views
I have recently had occasion to need to iterate my workspaces; that is, to run them multiple times on varying inputs.
When I need to do this on a group of files, I can pretty easily write a shell script to launch the workspace with a different input and output dataset for each of the input files.
However, I am now trying to extend this method to iterate over the feature types (in this case, Microstation .dgn levels) within a single file.  I can't seem to figure out a way to implement this, though.
I need to publish a parameter that controls which level is processed.  However, I can't seem to do that.  I can't create a reader for a single feature type and publish the parameter that picks which one (it is greyed out), and I can't read the whole file and filter it, because I can't seem to link the actual filter variables to a published parameter.
There is probably a way to do this, probably not even using shell scripts, but I can't figure out what it is.  Any ideas?
fmelizard
Forum|alt.badge.img+22
  • Mar 1, 2013 7:14 PM UTC
The feature types to read parameter controls the levels in the case of a dgn file  it is usually  automatically published when inserting a dgn reader.
davideagle
Forum|alt.badge.img+21
  • Mar 1, 2013 7:32 PM UTC
This is it:
And if you make your reader 'Dynamic' you won't need to worry when new levels that you didn't previously know about appear in your files.
  • Mar 1, 2013 8:22 PM UTC
OK, this looks good, and I'm much closer (thank you) ... but, I'm still stuck.
When I add the .dgn writer, I can either add the feature types individually, or merge them.  If I merge them, it looks like this won't work, because the writer treats them all as one feature type (albiet with different igds_level values).  If I don't merge them, then I can't generalize the transformer, because it will only create feature type readers for those features that are in this particular .dgn.  I am trying to get it to dynamically run on those feature types (levels) that are within whatever .dgn I give it, with me only having to edit the loop in my shell script.
sigtill
Forum|alt.badge.img+25
  • Mar 4, 2013 3:35 PM UTC
Hi Azeisinger!
You can try to use a FeatureReader in combination with an AttributeCreator. The AttributeCreator will take as input a text-field as a Published Parameter where you specify which Levels to load (for instance: "1201:1203" (remember, they have to be separated by a ":".
