Issues with XMLFragmenter
  • Jan 3, 2023 9:52 AM UTC
  • 157 views
nedwaterman
Forum|alt.badge.img+9
I'm trying to extract XML from the attached file. I'm using an XMLFormatter before hand which extracts the loggerId I need to match to a database table.
I can extract the XML using the fragmenter, but unless I use the 'Merge Attributes from Input Feature' the loggerID is not carried through. If I do this. FME managed to burn through 700GB of my hard drive and then fails due to lack of memory.
Any idea how I can carry through my original XML attributes through to the fragments without having to do this?
Best answer by david_r
First of all, be sure remove the incoming attribute containing the full XML after the XMLFragmenter. Otherwise you'll have a copy of the entire XML document for each feature output by the XMLFragmenter. That can eat up a lot of memory.
  • Jan 3, 2023 10:34 AM UTC
nedwaterman
  • Jan 3, 2023 11:40 AM UTC
Yes - that's much better. Cheers David!
