Issue:submitSyncJob with changes in Parameters
  • Jan 8, 2018 9:06 AM UTC
  • 70 views
Hi
After changing the params using
params += elem[i].name + "=" + elem[i].value + "&";
params = params.substr(0, params.length-1);
 I am unable to submit a job through FMEServer.submitSyncJob(repository, workspace, params, callback) function, but able to run using FMEServer.runDataDownload.
If i use the below line for params and do not change params:
params = { "publishedParameters" : [] };
then i am able to submit a job.
What is the probable reason for this behavior?
Best answer by takashi
Hi @dheeraj, because the FMEServer.submitSyncJob requires to receive parameters as a JSON object with this schema.
{ "publishedParameters" : [ { "name" : name, "value" : value }, { "name" : name, "value" : [ array_of_values ] }, ... ] }
See the JavaScript Library for FME Server Documentation to learn more.
  • Jan 8, 2018 9:35 AM UTC
  • Jan 8, 2018 9:59 AM UTC
Thanks Takashi..I was not aware of that.
