Is there / or how do I create a workspace that can change a private parameter [string] in other (different) workspaces?
  • Feb 21, 2019 2:20 PM UTC
  • 46 views
tschoppenhof
Forum|alt.badge.img+7
I have different workspaces with the same Private Parameter which I want to change. Is it possible to do that with an additional workspace where I can change all of the same private parameters togther? The Parameter itself is a string. I added an example Workspace with the including private parameter (Template File).
fmelizard
Forum|alt.badge.img+22
  • Feb 23, 2019 4:26 PM UTC
Hi @tschoppenhof It would be easiest to convert your Private Parameter to a Published Parameter.
