Is it possible to limit the amount of RAM available to a job?
  • Jun 16, 2016 1:06 PM UTC
  • 76 views
Forum|alt.badge.img+4
Hello,
on occasion while running a job the FME.exe will consume 99% of the available memory on my server thus causing much consternation for the IT folks.
Is it possible to limit the amount of RAM available to a process and/or set a time-out to kill a job if if runs for longer than ...
  • Jun 16, 2016 1:12 PM UTC
If you're running FME Desktop, you can adjust the memory usage by adding the line FME_ENGINE_MEMORY_REDLINE <value> to your workspace header, look under menu item Tools / Edit header.
Value should be between 0.1 (10% of available memory) and 1.0 (100% of available memory). The default is 0.5 (50% of available memory).
It's a bit of a hack (in my opinion), but worth a try.
If you're running FME Server, look here: https://knowledge.safe.com/articles/992/how-to-control-fme-server-engine-memory-usage.html
