Inheriting Credentials to use with FMEServerJobSubmitter
  • Mar 14, 2018 4:20 PM UTC
  • 46 views
Hello
I have a workbench which is launched from FME server by an end user, let's call it Workbench_A.
This workbench has an FMEServerJobSubmitter to call another workbench, Workbench_B.
Is it possible to somehow have the FMEServerJobSubmitter in Workbench_A inherit the credentials that were used to call Workbench_A, for using when calling the subjob Workbench_B?
I know of the FME Server parameter FME_SECURITY_USER, but I do not know of any password parameter. My alternatives are
1) hardcode a username and password on the FMEServerJobSubmitter, and
2) add Published Parameters to Workbench_A to have the end user provide their fme server credentials for use in the FMEServerJobSubmitter
Both of these are undesirable as option 1 has the usual issues surrounding hardcoding credentials anywhere, and option 2 could be confusing to the end user.
nielsgerrits
Forum|alt.badge.img+67
Why not use the api to start a workspace with a httpcaller. Generate a token with credentials in workspace a, start workspace b with token. Storing credentials not needed.
See also this topic. Let me know if you need more help.
