Incremental date as a new feature
  • Feb 6, 2018 9:39 PM UTC
  • 5 replies
  • 71 views
marsh007
Forum|alt.badge.img+11
I'm trying to get a range of dates as a new features.
For ex: if the date range is 02/01/2018 - 02/06/2018, Output features has to be like
02/01/2018,
02/02/2018,
02/03/2018,
02/04/2018,
02/05/2018,
02/06/2018
Any thoughts please? Thank You
Best answer by erik_jan
If you start with a parameter having the number of dates in the range and one for statdate:
Creator for a dummy object.
Cloner to create as many objects as dates in the range.
DateCalcukator to add a number of days using the _copynum from the cloner to the startdate.
And output the resulting dates.
marsh007
  • Feb 6, 2018 9:46 PM UTC
Tagging in @jlutherthomas, @Mark2AtSafe, @mark_1spatial, @erik_jan, @RylanAtSafe
erik_jan
Forum|alt.badge.img+26
  • Feb 6, 2018 9:51 PM UTC
marsh007
  • Feb 6, 2018 10:05 PM UTC
@erik_jan - Didn't get you. Couldn't add number of dates in parameter
can you please provide test workspace?
erik_jan
  • Feb 6, 2018 10:12 PM UTC
Sure, see attached daycreator.fmw
rylanatsafe
Forum|alt.badge.img+14
If you are using FME 2017.1 or Newer, I would recommend using the DateTimeCalculator – likely has the same results, but has the advantage of being a native transformer vs custom transformer.
Edit: Although, there might be some additional config necessary to get that clone to work.. @erik_jan has crafted a nice approach.
