Import module fme objects from FME 2017
  • Mar 6, 2017 3:45 PM UTC
  • 53 views
Hello everybody,
Last year i was programing some scripts in python that use the FME module call fmeobjects. Now, I am using FME 2017 (last version) and I want to use these scripts but they show me some errors.
Before I put the following lines in my code to import the libraries:
fmePydPath = "C:\\apps\\FME\\fmeobjects\\python27" #Python FME
fmePath = "C:\\apps\\FME\\" #FME
if fmePydPath not in sys.path: sys.path.append(fmePydPath)  #Try to add path
if fmePath not in sys.path: sys.path.append(fmePath) #Try to add path
Someone knows the directory for the new site? because I read that the directory is now in "C:\Program Files\FME" so i tried to put this code:
fmePydPath = "C:\\Program Files\\FME\\fmeobjects\\python27" #Python FME
fmePath = "C:\\Program Files\\FME\\" #FME
but i get the next error:
"ImportError: DLL load failed: %1 is not a valid win32 application."
Thanks for your help,
David M.
geosander
Forum|alt.badge.img+7
  • Mar 6, 2017 6:33 PM UTC
Your Python application (that calls FME objects) probably runs on a 32 bits Python installation, but your FME installation is a 64 bits version. Either install 32 bits FME or use a 64 bits Python installation.
  • Mar 8, 2017 4:10 PM UTC
Hi!
Man you are the best!! I didn't think in this way. Thanks a lot!
David M.
geosander
  • Mar 9, 2017 9:10 AM UTC
Hi!
David M.
No problem! Glad I could help :)
