if condition is possible run next Work flow
  • Sep 20, 2019 3:40 AM UTC
  • 19 views
rakeshreddy0996
i have two to FME Workflow process step-1 and step-2
Concept: after completion of step-1 there is a some manual actions required so then run step-2
step-1 outputs may get max four shape files
if nothing or one shape-file will export output of step-1 then auto-call for step-2
is there any possibilities plz suggest..... !
oscard
Forum|alt.badge.img+23
  • Sep 20, 2019 5:38 AM UTC
Wirte the SHAPES in a folder with the FeatureWriter. Connect the outpot port of the FeatureWriter to a FeatureReader for SHAPES reading that folder. If it finds anything, it will go on with the rest of the workflow connected to the FeatureReader.
