I want selected same like little difference names in a field
  • Dec 10, 2019 1:40 PM UTC
  • 10 replies
  • 110 views
tomjerry.vl
like these type of name in a field I want select
Ravindra BarathiRavindra barathiState Banck Of IndiaState Banck of IndiaRavi KiranRavi kiranRayamal PurRayamal purAndra PradeshAndra PradeshVijayavadaVijayaVada
  • Dec 10, 2019 1:42 PM UTC
You can use the FuzzyStringComparer or the FuzzyStringCompareFrom2Datasets.
  • Dec 10, 2019 1:46 PM UTC
If the only differences are in the case (and not in the spelling), you can simply convert everything to either upper or lower case before comparing.
Forum|alt.badge.img+63
Alternatively, since they all seem to concern differences in uppercase/lowercase usage, you can do the comparison with the @LowerCase() or @UpperCase() function.
becchr
Forum|alt.badge.img+35
  • Dec 10, 2019 1:47 PM UTC
i think in your example the only differences are the cases of some letters?
if this is the only difference you want to compare than you can set the comparison mode to 'case insensitive' in a tester for example:
tomjerry.vl
how to use the @LowerCase() or @UpperCase() function.
tomjerry.vl
it is a single field
  • Dec 10, 2019 2:12 PM UTC
You can also use the StringCaseChanger transformer.
  • Dec 10, 2019 3:13 PM UTC
Then you should go for @david_r's answer with the StringCaseChanger, using the Full Title Case setting.
lars_de_vries
Forum|alt.badge.img+10
If the attributes are in the same dataset, I would use the suggestion by @becchr, otherwise I would use the FME string functions as suggested by @redgeographics in a FeatureMerger. In that case you could use:
@LowerCase(@Value([fieldname]))
You should set that in both the Requestor and Supplier fields in the 'Join On' part.
tomjerry.vl
I don't want change replace the Characters just for identification
