I have a dataset with values of D15 (mm), D35 (mm), D50 (mm), D84 (mm), D95 (mm), & D100 (mm). I want to use stringreplacer to remove the letter "D" and "(mm)". Syntax to remove?
  • Aug 25, 2020 9:31 PM UTC
  • 83 views
Best answer by debbiatsafe
Hi @jencinas​
Try using the following Regex in the StringReplacer (Replace Regular Expression mode):
\D
This expression will identify any single character that is not a digit. Leave the Replacement Text parameter empty.
I hope this helps.
debbiatsafe
Forum|alt.badge.img+24
  • Aug 25, 2020 10:55 PM UTC
Hi @jencinas​
\D
I hope this helps.
  • Aug 25, 2020 11:28 PM UTC
Hi @jencinas​
\D
I hope this helps.
That was the solution! Thank you! I was able to use this suggestion and get the numbers by themselves. I wanted to sort those numbers and this allowed me to do so. Then, I used String Concatenator to add them back to the sorted numbers.  I appreciate your help! 🙂
