how to split the readers in seperate workspace connects to the second workspace
  • May 8, 2020 3:26 PM UTC
  • 46 views
i would like to create the readers in workspace and output of the first workspace as input for the second workspace .
i tried workspace runner but i did not get it to work
and i am not sure where can i find some articles about transponder sender and reciver if that what should i use
Fme 2018
any help plz and thanks
TransporterReceiver with TCPIP and establish will run until the other workbench with TCPIP and connect using the TransporterSender sends the data. The receiving workbench will sit there and run until it finally gets the data from the other workbench.
  • May 8, 2020 8:46 PM UTC
the output at second workspace has no schema
how could i solve that
let me know please also if i want to get temporarily file from first workspace then feed in the second workspace .how could i do that
Oh, sorry! You'll use an AttributeExposer after the TransporterRetriever. Either import the values from excel/csv or type in the ones you need.
  • May 11, 2020 4:19 AM UTC
thanks ,it is working
