How to initiate WorkspaceRunner?
  • Jun 24, 2016 6:04 PM UTC
  • 133 views
I have several separate workspaces I want to chain together. How can I get the first WorkspaceRunner transformer to start running with nothing preceding it?
I am using FME 2016.
Forum|alt.badge.img+7
Hi kevwin,
I don't think you can start a workspacerunner without anything preceding it. I would just use a creator to initiate the workspace.
Good luck
erik_jan
Forum|alt.badge.img+26
  • Jun 26, 2016 3:15 PM UTC
As Jeroen said: you need to trigger WorkSpaceRunner to execute. Creator (using default settings) can do that. If you want WorkSpaceRunner to import a file the "Directory and file Path" reader is often used. This reader returns file names that can be used as a parameter in the WorkSpaceRunner.
