How to get the Job ID from a failing FMEServerJobSubmitter?
  • Feb 8, 2017 8:45 PM UTC
  • 9 replies
  • 163 views
erik_jan
Forum|alt.badge.img+26
Using FME Server and Desktop 2016.1 I created a workspace calling a job on FME Server using the FMEServerJobSubmitter transformer.
The "Wait for server job to complete" is set to "Yes".
If the job succeeds I use the _job_id to get the log file and email using the file as attachment.
If the job fails (it generated a log file containing an error) I do not get the _job_id attribute (see image).
How can I retrieve the log file from the server if the job fails, but produces a log file?
This log file is even more urgent than the succeeded job's log file.
itay
Forum|alt.badge.img+19
  • Feb 8, 2017 8:55 PM UTC
Hoi @erik_jan,
You can use the REST API to query the falied jobs filter the one you are looking for and with the help of the job id,retrieve the job's logfile.
see the REST API documentation:
https://docs.safe.com/fme/html/FME_REST/v2/apidoc/index.html#!/transformations/list_get_11
https://docs.safe.com/fme/html/FME_REST/v2/apidoc/index.html#!/transformations/log_get_8
hope this helps.
erik_jan
  • Feb 8, 2017 8:58 PM UTC
Hoi @erik_jan,
hope this helps.
But don't you need the job id to check the status of the job?
I would expect the job id to be an output attribute (same as on succeeded jobs).
  • Feb 9, 2017 8:23 AM UTC
It is my experience that the FMEServerJobSubmitter in 2016 is buggy in this respect. As an example, the FMEServerJobSubmitter returns a different set of attributes depending on whether the master workspace is executed on Desktop and Server.
You might want to verify if that is the case for you, in my quick test it seems the FMEServerJobSubmitter does indeed return a _job_id attribute but 1) it is not automatically exposed in the workspace and 2) it is only available then the master workspace is running on Server, not on Desktop.
I think this has been improved in FME 2017, at least the _job_id attribute is now readily available on the <Rejected> port.
If nothing else works and you can't upgrade to 2017, you might want to consider using the REST API through the HTTPCaller rather than the FMEServerJobSubmitter to execute your child workspace, at least then you're guaranteed to get a job id.
erik_jan
  • Feb 9, 2017 3:02 PM UTC
Thanks @david_r. I will try the AttributeExposer and let you know the results.
itay
  • Feb 9, 2017 8:45 PM UTC
Not with the the section command that will result in all the jobs and their id's then it's a question of issueing a second command to retrieve the log file
itay
  • Feb 10, 2017 6:52 PM UTC
@erik_jan, just make sure you set the detail level to high ( when using v2 of the api) to get the ws name as part of the response.
http://yourserver/fmerest/v2/transformations/jobs/completed?detail=high&limit;=-1&offset;=-1
erik_jan
  • Feb 13, 2017 7:47 PM UTC
@david_r This seems to be working. Thanks again.
  • Jul 18, 2019 10:21 PM UTC
How do I fix this error?
  • Jul 19, 2019 6:15 AM UTC
I may be due to a problem that occurs before FME even gets to initialize the job log (e.g. startup scripts, etc). Have a look at the FME Server system logs and search for errors there.
