How to convert the latest ArcGIS Indoors data to IMDF?
  • Feb 9, 2019 12:46 AM UTC
  • 57 views
I have reviewed the workbench provided in this link(https://knowledge.safe.com/articles/73933/converting-arcgis-indoors-data-to-imdf.html?childToView=86665#comment-86665). Are there any additional steps that need to be taken for generating the imdf? The workbench was able to read openings but none of the other gdb features were getting read.
Your geodb source data schema probably does not exactly match the schema used in the Geodb to IMDF tutorial. You probably need to update the Geodb reader feature types, or import new ones. These steps are described in the FME Basic Training. You can also sign up for free online, instructor led training here , if you are relatively new to FME.
Once you have imported the schema of your source Geodb, you'll probably have to edit some of the AttributeMapper / AttributeCreator / AttributeValueMapper transformers to map your data model to the IMDF data model. Contact if you need more help with this process.
