How to Convert an int attribute to string so I can concatonate with aggregator?
  • Jul 15, 2016 2:07 PM UTC
  • 590 views
Im using an aggregator to merge some features and some of the fields are integers but I wish to concatenate them like strings, i.e 12,24,106
When I attempt this in the aggregator it has an error as the attribute it is writing the concatenated value back to is number format.
How can I change the type of these attributes to string before they enter the aggregator?
Seems I can find plenty about converting string to int but not much the other way around.
Thanks for the help
  • Jul 15, 2016 2:20 PM UTC
never mind, I think I was just using the string formatter wrong earlier, would remove this if I knew how.
Forum|alt.badge.img+5
Can you tell us what the error message is? I've tried this without problem and, in general, FME doesn't care about the attribute type in operations like this.
