How to control reader order with FeatureReaders?
  • Sep 6, 2016 7:07 AM UTC
  • 5 replies
  • 116 views
nielsgerrits
Forum|alt.badge.img+67
With the original readers / writers you could control reader / writer order in the Navigator to upgrade performance.
But in a workflow with only FeatureReaders I have a data table being read completely before the lookup table starts to read. This causes all my datafeatures collected at a FeatureMerger before the lookuptable is read.
Any way to do this?
Best answer by itay
Correct and if you are using a creator to trigger the featurereaders, you can now control the connection runtime exiting the creator(s), just right click on the connection > set connection runtime order
  • Sep 6, 2016 7:18 AM UTC
You should be able to control the order in which the FeatureReaders are fired by controlling the order of the incoming initiator features.
Or am I misunderstanding something?
itay
Forum|alt.badge.img+19
  • Sep 6, 2016 7:29 AM UTC
nielsgerrits
Sorry, my bad. Still getting used to FeatureReaders plus forgot FeatureMerger parameter Suppliers First.
nielsgerrits
Sweet, learned something new today! This looks more like the exact answer David.
  • Sep 6, 2016 9:44 AM UTC
Well, not everybody uses Creators to trigger their FeatureReaders. If that is the case, why not just use a regular reader?
