How to configure TXT structure
  • Oct 24, 2019 12:32 PM UTC
  • 6 replies
  • 109 views
lazarlubomir
Forum|alt.badge.img+11
Hello to all FME fans,
I have met one issue, how to configure transformers/writers for TXT with constant/dynamic content.
E.g. I just wanna generate TXT report with found errors, like below:
*TOPOLOGY ERRORS
FEATURE CLASS | OPACITY | ERROR | COUNT
Value(FT) | Value(O) | Valu(E) | 10
Please, as You can see, there mix of constant/dynamic (attribute) items.
How can I define to constant items its firm position (column 32) etc.?
Thank You so much!
Lubo
Best answer by ebygomm
One possible way of calculating the max length a field would be and using that as the value to pad the figures to make them a consistent length
csv22textline.fmwt
sigtill
Forum|alt.badge.img+25
  • Oct 24, 2019 12:36 PM UTC
Hi @lazarlubomir
The CAT (Column aligned writer) might help you. However I find it better to use a regular writer and then "parse" the lines according to the standard myself by creating each line "manually" using an Attributecreator. Especially if the style changes through the file - for instance 4 columns in the start, then a header, then a breakline etc.
Forum|alt.badge.img+54
  • Oct 24, 2019 12:53 PM UTC
I would use a stringpadder to pad whitespace up to a specific length before creating the text_line_data attribute
Might be a bit convoluted if you want to pad different attributes depending on the longest value
lazarlubomir
  • Oct 24, 2019 1:00 PM UTC
Hi @lazarlubomir
@sigtill,
unfortunately, CAT writer doesnt exist - only reader is available. As You recommend - Yes, it a way what I was thinking about, but I try to find "easier" way, how to do that.
itsmatt
Forum|alt.badge.img+48
  • Oct 24, 2019 3:06 PM UTC
Use an StringConcatenator to create single line/attribute with "Value(FT) | Value(O) | Valu(E) | 10 "
Use an Aggregator to merge the single line - (you can concatonate with a new line Character)
Then use another StringConcatenator to add the static content at the top and bottom of your Aggregated String.
Example attached
none2textline.fmw
  • Oct 24, 2019 7:22 PM UTC
csv22textline.fmwt
lazarlubomir
  • Oct 25, 2019 1:50 PM UTC
csv22textline.fmwt
@ebygomm,
this is what I exactly need!
Thank You so much!
