group by and assign value
  • Jun 1, 2016 11:07 AM UTC
  • 55 views
gis2020
Forum|alt.badge.img+5
Hi , i have table where the name are in two languages and there is another field/ column (sn_grp) with some values calculated only for one language so now i want to calculate that value for other language where the name and ID's are same .
  • Jun 1, 2016 11:23 AM UTC
Hi
You could use a Sorter to sort by ID (ascending) and sn_grp (descending). Then use an AttributeCreator to replace NULL values with the value from the preceeding feature:
For the value of sn_grp, use a conditional to test if a value is already present (do nothing) or if it is undefined (use the value from the preceeding feature):
David
gis2020
  • Jun 1, 2016 12:19 PM UTC
Hi
David
Thank you david ..it worked :-)
