Generic Writer (File GDB)
  • Feb 10, 2017 9:58 PM UTC
  • 76 views
runneals
Forum|alt.badge.img+32
I'm working on a project for FME Server where a user will be able to pass variables into a URL and get a download of a dataset. One of the requirements that I'm hitting a snag on is how to create a parameter that can be used to name the output file (geodatabase, pdf, or shapefile). Right now it's defaulting to dataset.gdb.
TIA,
David
Best answer by ciarab
@runneals If you create a published parameter just a simple text field and then link this parameter to the output destination like below
Now when you publish you can allow the end user to select the output file name
Or if you didnt want the end user to select you can still create a filename from this location with a timestamp or other required information
erik_jan
Forum|alt.badge.img+26
  • Feb 10, 2017 10:03 PM UTC
In general the Generic writer takes the parameters of any writer for that output format in the workspace.
So create a dummy writer for the GDB output (without a fetaure type to write to) and the Generic writer will inherit the parameters from that writer if the GDB format for the Generic writer is chosen.
ciarab
Forum|alt.badge.img+10
  • Feb 12, 2017 11:02 PM UTC
runneals
  • Feb 13, 2017 2:52 PM UTC
Doh! Thanks for the help, I didn't notice that until now.
