Generate measures on polylines with no measures attached in either coordinates or attribute table.
  • Sep 13, 2024 5:26 PM UTC
  • 5 replies
  • 184 views
fme
Forum|alt.badge.img+7
I tried generating measures on street segments but the measuregenerator is not calculating it right. It starts every segment  from 0 instead of calculating from the end log. Any ideas how to resolve or calculate measures on segments with no measures?
Thanks in advance!
bwn
Forum|alt.badge.img+26
  • Sep 14, 2024 2:59 AM UTC
You can put the Streets into Paths with LineCombiner, generate Measures along Paths with MeasureGenerator and then split these Paths back out the lines with PathSplitter.
Sample Data
fme
  • Oct 18, 2024 6:38 PM UTC
Thank you @bwn !
fme
  • Nov 7, 2024 6:36 PM UTC
Is there a way to convert measure from feet to miles? My coordinate system is in feet so measures were generated on the segments in feet instead of miles.
bwn
  • Nov 7, 2024 10:10 PM UTC
Use a different multiplier
fme
  • Dec 3, 2024 7:41 PM UTC
Thank you ​@bwn
