Ford circles not touching
  • Feb 18, 2014 4:40 PM UTC
  • 51 views
gio
Forum|alt.badge.img+15
Hi All,
I have made a fun script.
It makes ford circles with most math done by using listfunctions sorting etc.. So realy a minimal of actual math involved.
It works fine, except when one zooms in the some of the circles dont realy touch exactly as they should.
Anyone got a tip?
Still cant upload workbenches here.
Drop box is out of the question for me, can't install it due to rigorous network security.
I heard someone nmae another one, wich does'nt require software install. Forgot the name tho.
Im currently trying to do the circles in circle version, but i hav'nt yet figured out how to get complexnumber math working using fme.
(I made for instance a 3th-root custom transformer using aproximation (invovlves looping) rather then complexnumbers. Wich was needed to get that geeky heart formula working...but also needs complexnumber calculation..i got half a heart... )
  • Feb 19, 2014 3:57 AM UTC
Hi Gio,
Regarding gaps or overlaps between circles, I think those are caused by computational errors. There could be two kinds of errors in this case. One occurs when calculating, another occurs when drawing on the Viewer. I think that computational errors cannot be avoided.
You can use the Chatter to share files with Community members.
I uploaded demo edition there. Edit it freely.
https://safecommunity.force.com/069a0000003dfj7
Takashi
  • Feb 19, 2014 5:26 AM UTC
I guess "3rd-root" is same as "cubic root". What about using @pow function?
@pow(@Value(_value),1.0/3.0)
And regarding complex numbers, Tcl "math::complexnumbers" library can be used in the TclCaller. Although I've never used it...
http://docs.activestate.com/activetcl/8.4/tcllib/math/qcomplex.html
