Font has changed
  • May 13, 2020 10:01 AM UTC
  • 130 views
Hi!
I'm using FME Workbench 2019.0 and overnight it has changed the appearance. Now the font is totally different and can´t get back my original settings. According to FME options this new font is the default and definitely it isn't that one. How can I change it? Any help here? Not a big deal but annoying..
Thank you very much in advance!!
Forum|alt.badge.img+63
Is that font still available on your system? Can you find it in other applications?
  • May 13, 2020 11:43 AM UTC
Yes. It is there. I was using a normal simple one. And it is also in FME options. The problem is that it doesn't change the one that has appeared.
Now it says this is the default font. And even if i change it to for example arial, nothing happens. The same font remains...
Those only change the font used for transformers and annotations, the dialog boxes are not affected.
  • May 14, 2020 9:29 AM UTC
Thanks @redgeographics. Well, the point is that it does not change at all no matter what I do. Now font looks like this.
and also like this in may navigator.
I just want normal font and no this one.
Thanks!
