fmeworker suspended
  • Oct 27, 2017 2:52 PM UTC
  • 89 views
jdh
Forum|alt.badge.img+41
What would cause an an fme.exe/fmeworker.exe process to become suspended?
mark2atsafe
Forum|alt.badge.img+59
I believe it can be when you are using Feature Inspection mode (run with Full Inspection). When it hits a breakpoint the processes are suspended. Of course, that might not be the only occasion. FME hitting a memory or license limit and so temporarily stopping are other thoughts - but only guesses on my part.
Is it causing an issue or a slowdown? Do they ever start up again?
jdh
  • Oct 27, 2017 4:12 PM UTC
Not using feature inspection mode.
The processes hangs for until killed, ie they never start up again.
There should be enough memory. If I run the childworkspace independently it only has a peak process memory usage of 236500 kB.
davideagle
Forum|alt.badge.img+21
  • Oct 30, 2017 9:50 AM UTC
Inappropriate behaviour in the FME workplace, sorry 'Workspace'...
mark2atsafe
Well, I looked this up and found a few cases that showed the issue. There's not a consistent reason why the problems occurred - in some cases it seemed to fix itself (sometimes after a reinstall) and in other cases either the user was doing something wrong (writing to an invalid location) or the system itself was sick.
One item that was more definite: WorkspaceRunner was using the wrong FME (multiple versions were installed). So check the logs to make sure it is running the right FME for each child.
Otherwise I think the only way to sort it out is to send us a copy of your workspaces, and log files too, and see what we can figure out.
