FME works extremely slow
  • Sep 16, 2015 12:03 PM UTC
  • 133 views
Hi all,
I run FME workflow an hour ago, made some changes (not serious at all), and when I tried running it again, it reads GML data set extremely slow, really really slow. What could be the reason for this?
I restarted computer serveral times, emptied TEMP directory, diconnected from network, and now I don't know what to do.
Forum|alt.badge.img+5
  • Dec 2, 2015 3:35 AM UTC
How many features do you read ?
Your PC/Server follows these requirements ?
Recommended Requirements
  • Intel® Core i7 CPU
  • 8 GB of RAM (16 GB on a 64-bit OS)
  • 50 GB of available hard-disk space
  • A Solid State Drive (SSD) can provide significant
  • performance increases
Minimum Requirements
  • Intel® Pentium® 4 Processor
  • 4 GB of RAM (8 GB on a 64-bit OS)
  • 20 GB of available hard-disk space
Forum|alt.badge.img+63
In addition to what Julien asked, what were those changes that you made? Maybe they were serious after all.
fmelizard
Forum|alt.badge.img+22
  • Dec 2, 2015 5:20 PM UTC
Examine your log file carefully -- and turn on the timing output -- that should give some indication.
gio
Forum|alt.badge.img+15
  • Dec 2, 2015 5:27 PM UTC
Obiously the changes were very influential.
You migth have set some tolerance to tight, for instance. (i.e. Hullaccumulator is famous for that)
Or inadvertently forced a endless search. Or huge spatial comparisons.
Or created or forced fme into a so called "catastrofic regexp". This will slow things down seriuosly.
Show your workbench?
