FME - workbench - destination-folder?
  • Jul 13, 2021 2:26 PM UTC
  • 58 views
I'm having trouble getting a dwg writer to write multiple files. What is syntax in FME desktop v. 2019.0
If I write .... *. Dwg - then there are errors - probably because it writes all dgn files to the same dwg file - If I do not write anything there are also errors.
andreaatsafe
Forum|alt.badge.img+17
Hi @landinspektor​ ,
You'll need to use a dataset fanout and have an attribute to define how you want to write to different DGN files.
I'd recommend reviewing this article - specifically the "Dataset Fanout" section.
-Andrea
