FME Server .Net Connection
  • Mar 11, 2015 2:10 PM UTC
  • 53 views
we are trying to connect to FME Server 2014 programmatically via .NET.
We are using the sample code provided by the FME Server Documentation, but get following error:
{"QSIncompleteResponse:Incomplete FME Server response. Expected  [SUCCESS|ERROR]+message. Received: "}
The Server is running and the connection via web is successful. We have tried the code with enabled security and disabled security but both ways were unsuccessful. Our Code is attached:
Any Ideas what we are doing wrong?
Thanks in advance!
  • Mar 11, 2015 3:15 PM UTC
  • Mar 12, 2015 6:47 AM UTC
Hello David,
yes we used the documentation and sample project for our code. Nevertheless we get the above mentioned error.
Greetings!
  • Mar 12, 2015 8:21 AM UTC
Hello,
in that case, I suggest you contact Safe support (https://safecommunity.force.com/knowledgeSubmitCase), unless someone else here has an idea.
David
