fme server error
  • Jul 2, 2014 3:28 AM UTC
  • 5 replies
  • 64 views
I have installed 32 bit FME Desktop and created a workspace where it transfers a feature class from one file gdb to another . I have made the source dataset path as published parameter . I published the workspace to server and when I run the service I am getting below error
Unable to perform any licensing related tasks.  This is a 64-bit version of FME which requires a 64-bit version of ArcGIS Server. Or download and install a 32 bit version of FME. Refer to this this article http://fme.ly/qua for more details
  • Jul 2, 2014 7:06 AM UTC
you have probably installed a 64-bit version of FME Server. If so, the error message is correct.
David
  • Jul 2, 2014 11:55 AM UTC
Hello David,
So you are asking i need to install 32 bit FME Server ? is that right ?
  • Jul 2, 2014 12:03 PM UTC
the short story is: if you use 32-bit versions of ArcGIS, you need to use the 32-bit version of both FME Server and FME Desktop. If you use 64-bit versions of ArcGIS you need to use 64-bit versions of FME Server and FME Desktop. This is due to a limitation in the operating system and not in FME.
Here is more info:
David
  • Jul 2, 2014 3:54 PM UTC
Thanks David ..
  • May 4, 2016 3:02 AM UTC
It can still happen with 64bit of ArcGIS & 64bit of FME. It is not believed to be a different version issue even though the error message is saying like that, kind of misleading.
