FME Server Datum shifts for Canada & US both configure in same machine at different engines
  • Oct 9, 2018 6:39 PM UTC
  • 83 views
Can I configure multiple Datum shifts (both CANADA US) in same machine at different engines for FME server?
Best answer by hollyatsafe
Hi @balajiveera,
As described in the help documentation here in order to configure different FME Engines to use different default datum shifts you will need to have a distributed architecture with different engines on different machines.
It is not possible to have two datum shifts for different engines on a single machine, instead you would have to use the CSMapReprojector or Custom Coordinate Systems to define the datum shift for each job individually.
  • Oct 9, 2018 6:49 PM UTC
Hi @balajiveera,
Hi @balajiveera,
Thank you Holly
