FMe Server Chain Jobs - Data Downloader
  • Jun 10, 2013 3:47 PM UTC
  • 49 views
Hello,
I have been following this guide to chain FME Workbenches in FME Server: http://fmepedia.safe.com/articles/How_To/Chain-Jobs-in-FME-Server but I want to be able to download the resultant files at the end and can't figure out how best to do this.
I can register the Controller workbench in the Job Submitter repository and it works fine but putting it in the data download repository has no effect because there is no files to write to at the end as they are in the second chained workbench I use.
Thanks,
Peter.
sigtill
Forum|alt.badge.img+25
  • Jun 19, 2013 11:32 AM UTC
Hi!
Unfortunately I havent found a solution to this either. An option might be to copy the files generated in workspace1 to the directory of workspace2 by using a systemcaller. Anyone else have a solution to this?
jpvo
  • Jul 25, 2013 1:28 PM UTC
I tested the same workflow without success. Job submitter works fine but chaining datadownload jobs is still a problem for me.
In the end I got my customers to upload the output data downloaded from workspace 1 as input for workspace 2 but I don't like that solution.
Any suggestion is wecome.
JP.
