FME Server 2019 - Does FME Server allow all workspaces in a Repository to be run as an individual scheduled task?
  • Nov 1, 2019 7:10 AM UTC
  • 106 views
gfaulkner
I am wanting to publish around 60 workbenches to FME Server 2019 to run sequentially as a single scheduled task, however cannot find any configuration in the interface which would allow me to do this.
Ideally, I would want to be able to select the repository I publish the workbenches to and configure to run on one of our two engines of FME Server. This would save a lot of configuration time instead of having to create a unique schedule for every workbench.
Can anyone suggest a solution or advise if this is possible? (Maybe an idea for a future release of server?)
Thanks
Best answer by nielsgerrits
I do this using a FMEServerJobSubmitter or with a HttpCaller to the API. Schedule the single workspace that submits the children. Does that work for you?
nielsgerrits
Forum|alt.badge.img+67
Forum|alt.badge.img+63
In addition to what @nielsgerrits has already suggested you could also chain them together in one big automation and run that on a schedule.
Hi @gfaulkner,
I agree with nielsgerrits the easiest way to do this since you have so many workspaces to schedule would be to create a parent workspace to submit all of these. I'd take a look at the FME Server Rest API and first I'd make a call to list all the workspaces in that repository:
https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/repositories/items_get_5
Then you can flatten the response JSON to retrieve the workspace name as an attribute which can be used in a second HTTPCaller in the Request URL to submit the jobs, rather than this being something you have to set manually for each one.
https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/transformations/submit_post_29
There is also an existing idea requesting a Schedule for Repositories so please consider adding a vote and any supporting comments here: https://knowledge.safe.com/content/idea/77546/scheduling-a-repository-to-run-workspaces-as-a-bat.html
gfaulkner
  • Nov 11, 2019 11:47 PM UTC
Hi @gfaulkner,
@hollyatsafe @nielsgerrits @redgeographics
Hi All. thanks for your responses. I'll up vote the existing idea. We ended up using 4 parent workspaces with FMEServerJobSubmitter's to meet our needs.
Thanks again, Grant
