FME Reading Carto Database
  • Jul 24, 2017 4:51 AM UTC
  • 58 views
rudy_v
I am trying to connect to our carto database, but are getting HTTP error 404,
and also connection refused 443.
How do you connect to a Carto Database?
I am using out url address: com-luim.geografia.com.au and API key
Forum|alt.badge.img+63
The Carto account and API key should be enough, at least if it's hosted by Carto:
If you're using a local Carto server it might be a firewall issue. Can you access it succesfully through other means from the same machine?
Hi @rudy_v
Are you connecting to carto with a private account or a multiuser/organisation account?
I would try putting your username in the 'CARTO Account' parameter and the same under the Multiuser, if applicable.
trentatsafe
Forum|alt.badge.img+7
Just an update after working with @rudy_v.
When connecting to a Carto Database, ensure you know the host location of the database. If Carto is hosting the database, the connection parameters should be set up as @redgeographics posted. If the database is hosted locally(on premise), the Local settings must be used to connect.
