FME Python27 is deprecated and not able to use arcpy inside FME
  • Apr 15, 2020 6:37 AM UTC
  • 73 views
raaaju1990
Forum|alt.badge.img+11
I was using arcpy inside fme workbench. Till yesterday everything was good. Now today , FME python 27 has been deprecated and 'im not able to import arcpy module. Is there any workaround for this?
  • Apr 15, 2020 6:48 AM UTC
Python 2.7 has been deprecated since 1.1.2020, so it's not something that changed very recently. More info: https://knowledge.safe.com/articles/71635/python-27-deprecation.html
Did you upgrade FME? If so, you need to actively install the Python 2.7 libraries during installation.
Concerning arcpy, you need to make sure that the workspace points to a licensed installation of ArcGIS for Desktop (not ArcGIS Pro, which comes with Python 3.x). More info: https://knowledge.safe.com/articles/29799/importing-arcpy-troubleshooting-ideas.html
raaaju1990
  • Apr 15, 2020 9:07 AM UTC
Hi David, yes it was deprecated long back. Actually python 27 libraries were not installed during upgradation process of fme desktop. Now I have installed it. But, now when Im trying to use ESRI python interpretor , the FME throws error running translation and pop up windows saying fme.exe has stopped working. Not sure why. This was working fine till yesterday.
raaaju1990
  • Apr 15, 2020 9:09 AM UTC
Below is the message I get.
  • Apr 15, 2020 9:37 AM UTC
Am I right in assuming you have FME 64-bit and ArcGIS for Desktop with the 64-bit Background Geoprocessing as well?
