FME Job Submitter token
  • Oct 11, 2016 1:00 PM UTC
  • 14 replies
  • 236 views
How to use FME Jobsubmitter with one token without username and password ? thx
  • Oct 11, 2016 1:28 PM UTC
I don't think that's possible. You will probably have to use the transformations/commands/submit/<repository>/<workspace> API instead, e.g. using the HTTPCaller. The token is then sent in the http request header:
See also the documentation: https://docs.safe.com/fme/html/FME_REST/v2/apidoc/
  • Oct 11, 2016 1:30 PM UTC
FME desktop calls /fmerest/v2/info so i tried to add a token in the url but it doesn't work :(
  • Oct 11, 2016 2:19 PM UTC
Here's an example on how to submit a workspace to FME Server using the HTTPCaller, I've highlighted the important bits:
The upload body looks like this (see the API doc for details):
  "FMEDirectives": {},
  "NMDirectives": {
    "failureTopics": [],
    "successTopics": []
  "TMDirectives": {
    "rtc": false,
    "description": "",
    "priority": 100,
    "tag": ""
  "publishedParameters": [
  "subsection": "REST_SERVICE"
The response will be a JSON block with a job id, e.g.
{"id":6}
  • Oct 11, 2016 2:23 PM UTC
  "NMDirectives": {
    "successTopics": []
  "TMDirectives": {
    "rtc": false,
    "description": "",
    "priority": 100,
    "tag": ""
{"id":6}
Thank you for your help.
But it's not an issue for me to launch a workspace with a token.
I would like to use the FME Job Submitter with a Token without Username and Password. I don't want to show to the developers the credentials connection. I just want to expose a token with this transformer.
  • Oct 11, 2016 2:27 PM UTC
I don't think it's possible to use tokens with the FMEServerJobSubmitter, unfortunately.
You can easily convert the token to a published parameter using the above method, however.
  • Oct 11, 2016 2:30 PM UTC
One more thing, the password that you type into the FMEServerJobSubmitter dialog isn't readable to the naked eye by anyone with access to the workspace file. The protection isn't world-class, but it would be beyond most users to try and find the password from having access to the fmw file.
  • Oct 11, 2016 2:32 PM UTC
Wrong... https://knowledge.safe.com/questions/4499/pass-password-get-plaintext.html
It's very easy to decrypt the password with FME
  • Oct 11, 2016 2:41 PM UTC
Yes, I know. That's why I said it wasn't world-class ;-) But you still cannot see the password with the bare eye, so it's better than nothing.
If security is essential to you, you should of course not rely on that.
mark2atsafe
Forum|alt.badge.img+59
I think that should definitely be possible. I'm just looking for info now. But it seems pointless to have a service to generate tokens if you couldn't use them in a transformation service.
mark2atsafe
Oh, btw, what security are you using? Is it active directory?
  • Oct 11, 2016 4:58 PM UTC
Yes Active Directory
mark2atsafe
And are you calling the job submitter from a different machine? Because that could have CORS implications.
  • Oct 11, 2016 5:02 PM UTC
Yes, exactly and the CORS allows all hosts.
http://FMESERVER/fmerest/v2/info?token=blablablabla
  "NMDirectives": {
    "successTopics": []
  "TMDirectives": {
    "rtc": false,
    "description": "",
    "priority": 100,
    "tag": ""
{"id":6}
@Gistack Apologies, I know this response is a bit late!
Another option you could do here is wrapping up the HTTPCaller into a custom transformer, that way it would be repeatable and users wouldn't have to see and edit a HTTPCaller every time. That would also allow you to control which parameters a user can enter (such as token). @david_r is correct that currently you can only authorise with username/password.
You could always suggest this to the ideas exchange, for an updated/optional authorisation option within the FMESJS.
