FME If Else or Other Options to Sort Files by Filename
  • Jul 13, 2020 4:17 PM UTC
  • 78 views
Hi Everyone,
im new in FME and still learning a lot. I want to Sort some Files by their Filename.
For Example:
in Directory are few Files:
E006N52_ed2.zip
E025S23_ed4.zip
W312N34_ed1.zip
etc....
Now i want to Sort them by:
All E..... in one Way (Output on html as: All East Files)
All W.... in one Way (Output on html as: All West Files)
Hope u understand what i mean ;)
Greetings
caracadrian
Forum|alt.badge.img+23
  • Jul 14, 2020 11:13 AM UTC
You can use the FeatureWriter transformer with File Copy Format, the filecopy_dest_dataset set to a Conditional Value with Test Cluses set to filename Begins with E and W respectively and Expressions of the paths for each situation
davtorgh
Forum|alt.badge.img+12
  • Aug 11, 2020 3:11 PM UTC
Hi @zentalas​,
I'm not sure I got it right, but if you want to get an ordered dataset containing a filtered subset of the files in a directory (and subdirectory), you can use a Directory and File Pathnames Reader (check the attached screenshot for setup) followed by:
  • a Tester on the 'path_filename' attribute to get only the fatures (filenames) you want;
  • a Sorter on the same attirbute.
Hope that helps!
