FME Feature Store (FFS) has no WHERE Clause, workaround?
  • Oct 8, 2013 7:15 PM UTC
  • 5 replies
  • 82 views
samisnunu
Forum|alt.badge.img+15
Hi:
What would be a work around to filter the features in the FFS reader, similar to other data readers that have the WHERE Clause parameter?
fmelizard
Forum|alt.badge.img+22
  • Oct 8, 2013 8:25 PM UTC
Place a tester or testfilfer after the reader .
samisnunu
  • Oct 8, 2013 9:22 PM UTC
No.. this approach I want to exclude,  I have a big FFS file( =long time for reading), that I don't want to read its whole content in order to pick certain records .
  • Oct 9, 2013 2:00 AM UTC
The query functionality like "WHERE Clause" seems to be available only in a dataset which will be accessed from the reader via middle ware having a query mechanism (typically DBMS: database management system).
I don't think FFS has such a mechanism, unfortunately.
Takashi
jelle
Forum|alt.badge.img+23
  • Oct 9, 2013 5:10 AM UTC
Hi, I imagine you create the ffs file yourself, since it is an FME format. Why not create/prepare different ffs files, with the right TestFilters? Best regards, Jelle
fmelizard
  • Oct 9, 2013 6:15 AM UTC
Other the using the features type to read parameter and the suggestions here, you are out of luck....
