FME desktop VDB connection
  • Mar 17, 2017 2:11 PM UTC
  • 10 replies
  • 66 views
I'm new on FME and I've to copy data from a VDB to oracle. I'm working with FME 2013 SP4, I think I've to initiate a new reader with the JDBC driver but I don't know how.
Is it possible to have some help/information about that ?
Thanks by advance,
Slop
  • Mar 17, 2017 3:28 PM UTC
For those of us that don't know, what is a "VDB connection"? I can't find anything by that name in the FME reader/writer gallery.
  • Mar 17, 2017 3:31 PM UTC
VDB for virtual database, in my case Teiid. I havn't find anything about that in the gallery.
  • Mar 17, 2017 3:50 PM UTC
I don't know that format at all, but hopefully section 1.1 Driver Connection on this page can help you with the connection string and java driver class name for the JDBC reader/writer.
  • Mar 17, 2017 4:02 PM UTC
Thx for the answer, but the question now is, how to use that on FME ? Wich format can I use on my reader ?
  • Mar 17, 2017 4:06 PM UTC
Try the JDBC reader, my guess would be something like this:
Obviously the parameters above are made up, I haven't got an instance of Teiid to test against.
  • Mar 17, 2017 4:14 PM UTC
I havn't JDBC format on my gallery :( that's the problem
  • Mar 17, 2017 4:25 PM UTC
Ah, I didn't notice that you were on FME 2013. You'll have to upgrade as the JDBC support was introduced with FME 2015.0
You can download the latest version of FME here:
http://www.safe.com/support/support-resources/fme-downloads/
Or older versions here:
http://www.safe.com/support/support-resources/fme-downloads/archived/
If you need to preserve your old version you can simply install a newer version of FME in a separate directory, they will coexist nicely.
  • Mar 17, 2017 4:48 PM UTC
Humm I'll see if we can upgrade our FME version but I don't think so. I mean we could but we'll have to upgrade our server etc...
I'm trying to initiate a reader with the Postgre format and it almost worked :
But, I've an error on the "Constraints" section, any information about that ?
Here is the error :
Thanks by advance
  • Mar 20, 2017 8:02 AM UTC
Make sure that the "powerbi" user has sufficient rights, in particular SELECT rights on the "pg_tables" object.
  • Mar 22, 2017 9:03 AM UTC
Yes the user has sufficient rights. We'll upgrade our version to 2015.
Thanks for your help :)
