FME Challenge: 12 Days of FME Hackathon
  • Nov 30, 2017 10:33 PM UTC
  • 79 replies
  • 686 views
Show first post
runneals
Forum|alt.badge.img+32
  • Dec 14, 2017 12:11 AM UTC
TITLE:
Predicting football results using FME. Reducing hours of analysis down to 10 seconds.
BRIEF DESCRIPTION:
There are hundreds of football games taking place across Europe each weekend. To determine the best matches to place a wager can be very difficult. Using open data (upcoming fixtures compared with historical form) I am using FME to quickly analyse the matches that are best to bet on each game week. What used to take hours to analyse is now being achieved using an FME workspace that takes under 10 seconds to run. I have it set up on FME Server to send me (and my friends!) an email each time there are new decent bets available. It also now tweets from a new dedicated account @deadcerts.
I'm sharing the workspace here, and hopefully I will get some feedback and improvements from other tied up with FME and Football as their main work/hoby! If you make any improvements, which I'm sure you will, then maybe we can collaborate on a Github project? You can contact me @pinpointalerts
DOWNLOAD THE WORKSPACE:
fme-football-predictor.zip
I mentor a high school FIRST Robotics team and was pretty close to trying to integrate FME into our scouting system to do something similar except more for scouting and strategizing than betting :P, but never got it out of an idea. Interesting use for it.
runneals
  • Dec 14, 2017 12:12 AM UTC
Now having FME Server ring you back to tell the answer (trying to skip any voicemail services and retrying every five minutes as long as no real life contact was made)! Well done.
More like having FME Server call you to let you know it is sick (jobs failing) and needs some attention would be awesome... But all those phone calls :P At least it could get you out of some important meetings xD
revesz
Forum|alt.badge.img+22
  • Dec 14, 2017 5:19 PM UTC
Ooh, I wonder what DanRSecret.fmw does. I suppose you'll tell me it's a secret!!
Yep, because Dan says it is a secret
runneals
  • Dec 14, 2017 6:13 PM UTC
Inspiration for this project was: https://www.3ders.org/articles/20161220-3d-printed-gingerbread-house-lets-you-celebrate-christmas-the-scandinavian-way.html
a) GingerbreadhouseGenerator b) Converts your fancy 3D-modelled house (for instance from Sketchup) to a 2D-model possible to print and build a gingerbreadhouse from the parts! c) Workspace can be sent upon requests by commenting this article. Below are the steps used in the workspace! I do not guarantee for the printed papers and the finished 3D Gingerbreadhouse! 1. Select area with house:
2. Look at the result in Sketcup
3. Get a single house:
4. Explode the house into individual parts:
5. Workspace with description
6. End result - one PDF per part - and the simple PDF
7. Rent a bakery and print all the roughly 40 000 000 + parts to all the 2 770 000+ houses in Norway (TODO)
TODO if enough interest:
- Bake the house
- Rotate the geoemetries to "flat surface" by using the SurfaceNormalCalculator and 3DAffiner to get correct geometries.
I just got to looking and that's a lot of wasted paper and gingerbread if you have 32+ sheets xD
runneals
  • Dec 14, 2017 6:26 PM UTC
Interesting.
I recommend better error catching if there is an invalid port.  Currently it is
2017-12-11 15:09:53| 0.6| 0.0|WARN |Python Exception <TypeError>: Input must be a string or unicode.
2017-12-11 15:09:53| 0.6| 0.0|WARN |Traceback (most recent call last):
File "<string>", line 98, in close
File "<string>", line 23, in throw
TypeError: Input must be a string or unicode.
2017-12-11 15:09:53| 0.6| 0.0|FATAL |f_70(PythonFactory): PythonFactory failed to close properly
2017-12-11 15:09:53| 0.6| 0.0|ERROR |f_70(PythonFactory): A fatal error has occurred. Check the logfile above for details
I would also be very interested in checking all the licences on a specific server in one shot, or at least all the licences for a specific version of flexlm.  (We have 6 software requiring 3 versions of flexlm on the same license server)
Is that what that error meant? It seemed more like a python bug than putting in an invalid port number.
runneals
  • Dec 14, 2017 6:28 PM UTC
A title.
Server log saver and timeline visualizer
A brief description.
We have more and more schedules and I was less and less enthusiast to go through long-long list of logs (instead of building a snowman army for example now ???) when someone didn't like something
Half a year ago I opted not to care with a few SLAs and build something visual (no, I cannot build nice tings) that save me some boring time ?.
I end up with this.
The workspace saves the Server log to a staging table (on request) for future reference. No cleanup now, the size of the table is the discretion whoever cares with it.
The timeline control is Google Charts (sorry anyone from China). It is not my dream as a timeline (no control over individual colours, no navigation, etc) but I just couldn't find anything decent. Until I hack one (that would look as nice as FME Server Schedules Dashboard inspiration) I chose a quick win solution temporarily.
fme-job-history-to-google-timeline.fmw
Why do you dive into the server db? Why not use the API to request server logs like the workspace does for the FME dashboard?
Forum|alt.badge.img+54
  • Dec 14, 2017 7:36 PM UTC
- Bake the house
Going to have to make a sketchup model of the Innderdalshytta so I can compare the fme produced pattern to my hand made one :-)
https://www.flickr.com/photos/ebygomm/5336924990/in/photolist-98B9ef-98xZqe-98B8S7
revesz
  • Dec 15, 2017 2:41 AM UTC
Yes, the API is a good point for a solution in FME dashboard showing the job history residing in the FME DB.
However I wanted to see jobs older than what the cleanup settings keep.
I don't want to overload the FME DB job history table either, so I keep all historic job data in a separate "staging" table. (It holds 55k+ records from the last half year). It is more convenient to query the new records from the FME DB table and push to the staging one than converting the json, too.
  • Dec 15, 2017 8:32 AM UTC
Fantastic!
sigtill
Forum|alt.badge.img+25
  • Dec 15, 2017 8:17 PM UTC
Your Gingebreadhouse and the image from David is more impressive than the 3D-model, thats for sure! For some reason I can not upload an image right now, I`ll try again later - but it can also be viewed here: https://imgur.com/qrBOkhn
sigtill
  • Dec 15, 2017 8:18 PM UTC
yup, v2 will include more parts on a single paper - to make an environmentalfriendly gingerhousetemplate
  • Dec 18, 2017 7:21 AM UTC
For when the time comes ;-)
https://en.wikipedia.org/wiki/Bin_packing_problem
jdh
Forum|alt.badge.img+41
  • Dec 18, 2017 5:12 PM UTC
If you put in an invalid port number, then you get a python exception error.
I only know this because I was testing the various licences we have, and I accidentally used the wrong flexlm/port combination.
It would be great if the exception was caught and a better error message returned.
sigtill
  • Dec 18, 2017 5:54 PM UTC
Oh, already pythonized the problem! https://github.com/secnot/rectpack
sigtill
  • Dec 18, 2017 5:55 PM UTC
Now I can post the image:
fmelizard
  • Dec 18, 2017 7:37 PM UTC
- Bake the house
This actually works, amazed.
davideagle
Forum|alt.badge.img+21
There is definitely a problem with the Python, I use it to handle a pivot of the license usage stats and that part needs cleaning up before I release this properly. But, thank you very much for the comments as that highlights what I need to test when I give this more than the "hack" I've given it so far. Happy Christmas all!
davideagle
  • Dec 18, 2017 7:41 PM UTC
Interesting.
@jdh so in that case would you want to be able to point this at multiple license server root directories at the same time or, would more than 1 FlexNetAnalyser in the same process with shared parameters be acceptable? Thanks for the feedback!
jdh
  • Dec 18, 2017 7:42 PM UTC
I'll be happy to beta test. This is the "hack" I'm most likely to benefit from - even more than my own :)
davideagle
Yeah, what's up with the password? Got some dirty tricks to hide, Dave? ;-)
No, just some dirty Python I need to give some more attention! But then you know all about that kind of thing eh! ;-)
jdh
  • Dec 18, 2017 7:46 PM UTC
In my dream world I would be able to point it to a machine, and it would magically figure out all the flexnet licenses in use.
In a more realistic world, I would point it to a specific license server root directory, but not have to specify the port, and it would return all the licenses visible on that instance.
davideagle
  • Dec 18, 2017 7:49 PM UTC
Your dreams are partly intreguing and partly unnerving... I'll see what I can do!
How about the dream world where FME doesn't use Flexnet? :) #comingsoon
davideagle
  • Dec 18, 2017 7:55 PM UTC
Thankfully this transformer also works with your Esri and Autodesk license servers too... #aintgoingawayanytimesoon
jdh
  • Dec 18, 2017 7:56 PM UTC
Honestly, not something I'm really looking forward to, as I still need flexnet for my esri, autodesk, presagis and hexagon software, so it'll just mean I need to manage licenses in different interfaces.
