FME Bug passing wrong parameters to fme workspace runner
  • Jun 30, 2017 4:39 PM UTC
  • 9 replies
  • 81 views
In my workflow I have a main process which executes other workspace runners and passes published parameters of the main process to the workspace runners. One of these parameters is a text separated by comma (student_list) and when it is passed to the workspace runner is not getting interpreted as a text, but as multiple parameters.
This is the main workflow:
When Student_List is passed to the workspace:
StudentElegibilityProcess: {C:/Program Files/FME/fme} G:/Git/compass-fme/student-eligibility/student-eligibility.fmw --ScenarioGuid *** --OrgGuid *** --DbServer *** --DbName *** --DbUserName ** --DbPassword *** --AuditFile {G:\Git\compass-fme\student-eligibility//audit_eligibility.json} --ALLOWS_OUT_OF_BOUNDARY_TRANSPORTATION true --SOLVE_CLOSEST_FACILITY_BATCH_SIZE 100 --STUDENT_LIST 000157141 --000170660 000171155 --ZonesUrl http://*** --HazardZonesUrl http://**r 2>@1
erik_jan
Forum|alt.badge.img+26
  • Jun 30, 2017 4:51 PM UTC
Have you tried embedding the student list in double quotes: "00157141, 00170660, 00171155" ?
  • Jun 30, 2017 4:53 PM UTC
yes, it doesn't work
erik_jan
  • Jun 30, 2017 4:56 PM UTC
Then submit this to support@safe.com as it seems to be not the right way to handle these parameters.
  • Jun 30, 2017 7:39 PM UTC
This is a known bug, you can work around it be re-defining the published parameter in the child workspace from "Text" to "Text (multiline)". That should let you pass comma-separated values.
  • Jun 30, 2017 9:32 PM UTC
It's doing the same even with Text (multiline)
  • Jul 3, 2017 7:19 AM UTC
Which version of FME are you using?
  • Jul 3, 2017 8:10 AM UTC
  • Jul 4, 2017 2:09 PM UTC
2017.0.1.1 Build 17291 win64
rylanatsafe
Forum|alt.badge.img+14
Hi @rrdlpl, I'm sorry for the inconvenience experienced here!
I tested in 2017.0 Build 17291 and I was able to reproduce this behaviour. However, when testing with 2017.1 Build 17521 the values were passed through as expected without issue.
I haven't identified the specific fix that changed this behaviour, but I encourage you to test with the latest FME 2017.1 Beta to ensure your workflow operates as expected in the newer version.
safe.com/beta
Additional thanks to @david_r and @erik_jan for their support here! :)
