FME 2013 SP1 What's new Build Numbers
  • Mar 22, 2013 1:20 PM UTC
  • 79 views
mhab
Forum|alt.badge.img+10
Hello
My question refers to the What's New Info which comes with FME 2013 SP1
The What's New in the "latest" official FME 2013 says for the latest change:
     BUILD 13264  20130207
The What's New for FME 2013 SP1 starts with the oldest entry:
     BUILD 13400 20121109
and ends with the latest entry:
     BUILD 13448 20130319
My questions:
  • Why is Build 13400 from Nov. 2012 when Build 13264 is from Feb 2013 ? I thought Build numbers are counted upwards ;-)
  • What happened between 13264 and 13400 ?
I' m sure there is a simple answer, but still I am confused ...
Michael
fmelizard
Forum|alt.badge.img+22
  • Mar 26, 2013 5:04 PM UTC
Hi Michael,
Good question! Here's what is going on.
Before we released FME 2013, we "branched" the code and started a new codestream for FME 2013 SP1.  This happened in Nov.  So for a while, there were 2 FME 2013s being built -- the release one, and the SP1 "candidate/preview". Because we didn't know how many changes we'd make to the "release" one in Nov, we left a gap of build numbers and started the SP1 build numbers at 13400.  So, at some point within Safe's office, there was, for example, a buid 13250 and a build 13403 (numbers are made up).  We also made sure that any changes made in 132** were pushed up daily into 134**, so the 134** builds always had whatever was in the 132**, plus whatever else we were doing on SP1.
So the gap from 13264 to 13400 is truly empty, which means we left ourselves plenty of room.
Note -- for SP2, there will be no build gap like this -- we are not branching and did not do concurrent development on SP1 and SP2.
And final note -- though I'm out of office I've heard that there is going to be a hotfix build for SP1 which will repair a regression for those authoring new custom xformers, so there will be one more Sp1 "hotfix" build to watch for.. and then that is it, just SP2 betas...
mhab
  • Mar 26, 2013 9:52 PM UTC
Thanks Dale for the in depth clarification.
Michael
