Filter by Wildcard
  • Nov 8, 2016 1:34 PM UTC
  • 93 views
I have a date attribute in the format %Y%m%d%H%M%S. I want to use everything in 2016, so how can I create a wildcard similar to 2016% ?
Forum|alt.badge.img+63
You can use the option begins with in the Tester or Testfilter, or a StringSearcher and then use ^2016 as the regular expression.
itay
Forum|alt.badge.img+19
  • Nov 8, 2016 2:05 PM UTC
If your data is in a database you could use the underlaying database syntax to request only the 2016 data
erik_jan
Forum|alt.badge.img+26
  • Nov 8, 2016 3:46 PM UTC
Or you could use the SubstringExtractor to create a YEAR attribute (Substring 0 - 3) and use that in the AttributeFilter transformer.
